Radial Tires
deputydog
Member Posts: 103
According to codes listed on T@B tires they are of the cheaper or cheapest tire that can be purchased. Has any one purchased a radial tire . Concerned these may not be the best to be travel with.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
My 2015 came with steel belted radials.
Little Guy changed to radial tires in 2013. I've had two sets of them, but not due to being a bad tire. The second set was damaged by an accident.Verna, Columbus, IN
My information was received by my neighbor whom stated he ran the codes. I feel like and idiot posted an negative statement about t@b. They have treated me BETTER than any customer I think. Next time I will speak to T@B form FIRST. Thank You both.
Called T@B factory, still thinking about tires? Techs stated Radial tires were started on the T@b models beginning in Sept 2015. However they have had No reports of problems with past tires. Even though my T@B was purchased in AUG., this has eased my mind.
deputydog I assume that was meant to be September 2014.
I will have to check mine as that was around the time my T@B was built.
I was was also wondering if anyone had decided to not carry a spare but rather a can of puncture seal and 12 volt tire inflator.Martin - Trailer name: James T@Berius Kirk -
mawebb Yes, my T@B was made in month of Aug 2014
mawebb Again wrote wrong year. DAH Radials on built T@Bs starting in Sept. 2015.
Mawebb...while I still carry a spare tire for the t@b, I also carry a tire puncture kit and a can of fix a flat and an inflator. So many tires today can be easily repaired on the roadside with these kits. Rather repair a tire and keep the spare good for emergencies. If both tires go flat and one can be repaired then I can replace both... Saw a RV on I 70 this summer with this type of tire accident due to debris on road. Tires...Batteries... Gasoline...still the top 3 road hazards...right ?
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
