Just a heads up while towing. My battery is not being charged when towing and the switch in the off position.
I'm mentioning this because when I read the 2017 owner's manual here page 16 states that your TV charges your battery regardless of switch position.
Maybe because mine is a 2016 they wired them differently. This is not a knock just a FYI.
2016 CS-S silver and red, 2022 Toyota Sienna Hybrid
Ottawa, Ontario
0 ·
Ottawa, Ontario
Anyway, if my understanding is correct, with the battery power cut off via the switch, if the trailer became disconnected entirely from the tow vehicle, and the breakaway pin got pulled, there would be no electricity to activate the emergency braking. I believe this is what Z_G was referring to. The brakes should brake fine when connected to the tow vehicle.
So I should tow with switch on all the time. Btw I've camped many times in Grundy PP, good park.rkj__ said:
Ottawa, Ontario
Before the days of factory supplied switches, some of us installed cut-offs inside the camper under the driver's side bench, on the wire that feeds the converter. In those cases, you can leave the switch off and still charge you battery and power your breakaway brakes while driving. However, I think the vast majority of T@Bs have the switch at the battery.
I live in a condo and my tab is in a storage place so no way of charging other than bringing battery home.
I think I will trace out some wires and see if I can figure something out.
Ottawa, Ontario
New surprises everyday
See beautiful world
For reference, here's a diagram of how the 12V+ lines connect in the junction box under the front of my 2015 S. Nothing else splices into any of these cables between the terminal and the indicated device.
You can see why in this case disconnecting the "battery" line removes the battery from both the T/V charging circuit and the breakaway brake circuit.
I wonder, the builders must work off a wiring diagram. Would be nice to see it to better understand the set-up.
Ottawa, Ontario
Be sure to read the fine print, however. Things do change and what applies to one trailer may not apply to another. The only way to know for sure is to start tracing the wiring in your own camper (as you suggested)!
