Clamshell galley tent
Marceline
Marceline Member Posts: 1,779
edited March 2019 in Products and Accessories
Has anyone tried either of these options:
https://tailveil.com/
https://www.amazon.com/dp/B00NGJEN5K/
  • manny
    manny Member Posts: 108
    Hey, Marceline   I looking at the  Hasika Awning Camper Trailer roof top  $109 at amazon  ...Ihave a 2017 CS-S   don't know if it will work  it shows a pic of a T@G...  A lot cheaper then the $750 for the pahaque clamshell tent...   good luck & shopping
  • Marceline
    Thanks but I got murdered by mosquitoes at Diamond Lake (OR) last month so I'm looking for something that's fully enclosed. I'm trying to see if there is something that's cheaper than the PahaQue that will work. If all else fails I'll fabricate something out of mosquito netting.
    Marceline, the PahaQue tail veil for the Tab is pricey and does not look very spacious.  I understand the need to hide from the bugs.  You may consider https://www.amazon.com/Plow-Hearth-Umbrella-Mosquito-Zippered/dp/B009YZ5RKK/ref=sr_1_2?ie=UTF8&qid=1501971010&sr=8-2&keywords=umbrella+netting.  An inexpensive way to keep the bugs off.
  • Homebodyatheart
    Amazon also has these nets, which might also work attached to a pop up awning or something. For $20 it might be worth a try.
    https://www.amazon.com/dp/B01KKMZRFK/_encoding=UTF8?coliid=I3FM2PPVTMYTW6&colid=1TLEVFC9JYU7H
    Found this over on the TaG forum.  If it is tall enough for a minivan, it may work for a CS.
    http://www.rightlinegear.com/suv-tent.html
