Hi - my 2006 TAB has electrical issue.  the shore power works great.  but no power from battery.  replaced battery.  also replaced the short stop that sits between the battery and the TAB power and one of the wires had a rusty end so replaced that.  still no power from battery.  only thing I can figure is the converter box has gone bad.  looked where all the wiring is hooked up to converter and not seeing any disconnected wires.  any suggestions to trouble shoot further?
                0 ·
Alan & Patty
Southern Az
If you've replaced the battery and can get no power to the 12 volt devices inside you either have a blown fuse on the positive end just off the battery or possibly blown fuses in the inverter. You may also have your wiring at the battery hooked up wrong as that's happened to people in the past too.
