Construction time?
sherm2954
Member Posts: 38
I've been researching trailers for about 18 months. I haven't found any with the fit and finish of the nuCamp or Little Guy.
Can anyone tell me if they know how long it takes the factory to build a 320 or 400? Little Guy Max?
Just curious, because it seems that if you can build a 24' trailer in less than 8 hours, something is going to have to be sacrificed.
Thanks
Thanks
@sherm2954 I know this is apples to oranges (that never stops me), but I never thought of that question so, this from a Toyota site:
"The process of making a car can be roughly divided into stamping, welding, painting, assembly and inspections, which takes about 17-18 hours in total. (It varies according to the number of cars made by a factory.)
When we consider that each car is made of about 30,000 parts, each of which takes time to produce, the time it takes to build a car is quite long."
It it will be very interesting if someone can compare apples to apples!John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
It used to take 11 hours to build one T@B 320, but I haven't heard in the past two or three years if that has changed. I have no information on the T@B 400 as that production line is still working on quality first, production last.
nüCamp is no longer associated with Little Guy, nor their products.
I always prefer quality over speed. As a friend once told me, " If you want something done real bad, that's what you will get."
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
