jkjenn
Member Posts: 6,417
I am considering a couple of 5 day stints at campgrounds without dump stations. They have pit toilets, so I will use them, minus the occasional late or middle of the night event. But, what about your grey water. I think my T@b holds 11 gallons, which is not a lot. Does anyone use one and if so, what size and what advice can you offer to help me get it inside the TV to take to a dump station? In one case I am planning on a NP Campground and in another a FS CG.
PS, I am familiar with water conservation techniques.
Sterling, VA
It kind of comes down to the actual sites you're in - relaxed rules in some, others more strict. Some of the BLM around Quartzite even allow you to dig your own toilet hole (cat hole?)
Some dump sites are a ways away, probably too far to tow behind the Jeep - Would you then load it into the Jeep?
The only time I've seen anyone with/using a tote was within a campgrounds that had a dump station so they didn't have to haul it more than a city block or two.
