Valterra F02-3106BK Black Bulk EZ Coupler Valve Cap with Handle
luvmytab
Member Posts: 66
Anyone try this? I am worried my black tank cap will open while on the road, leaving a trail of you know what behind me.
Here is the link: https://www.amazon.com/Valterra-F02-3106BK-Black-Coupler-Handle/dp/B0006MRR2Q/ref=sr_1_3?s=automotive&ie=UTF8&qid=1505858824&sr=1-3&keywords=sewer+cap#Ask
Barbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner
No, but although we've never had a problem with our cap in 3 years I like the design. If your cap does fall off the gate valve would hold any fluids back...
J.D. & Sue
Looks good and may give you better leverage and the ability to apply better pressure when removing or installing the cap. I can see some advantages if you have problems griping and removing or re-installing the cap. Keep us posted if you buy and use this product.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
will do.......glad to hear the lever is keeping it in, makes sense. I had a mishap first time out 2 years ago, not attached to the hitch properly so trailer dropped and broke the valve caps......they are barely hanging in there. I will order and keep you posted. thanks!Barbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner
Agree with Durango... I camped north of Sante Fe in early spring and when I went to leave I noticed the gray tank pipe was gone!!! The valve was intact and it did take some creative dumping to get the gray water out. I had to call the factory, have a replacement pipe shipped out to a dealer in Colorado Springs and I ended up reinstalling the attachment (with cap) in a campground in Manitou Springs.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
yikes.....it sounds like it was the valve pipe that broke and not the valve cap..... gosh, do we need to have extra valve pipes in our tool kit? Do you know how it broke?Barbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner
I have the linked cap on both my outlets, not because they seal better but because they are much easier to operate with my aging hands. They work great.John and Henrietta, Late 2016 T@B S Max in Western New York
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
