Roof vent hand crank 320 cs s
Blue
Member Posts: 4
we have somehow discombobulated this crank and cannot open the vent or operate the fan. Any ideas?
Is the vent (lid) lock engaged?
James & Jacquie Almonte, Ontario
2016 Jeep Cherokee & 2017 T@B Outback1 -
Agree with Hymie, you probably have the lock engaged on the vent cover that locks the cover in place. You will need to turn the lever handle to disengage it and once this is done you should be able to able to fully open the vent cover. Once the vent cover is extended upward some, there is a built in switch that activates the fan motor (activates after the cover is raised about half way up) when you are using the fans speed control.Blue said:we have somehow discombobulated this crank and cannot open the vent or operate the fan. Any ideas?Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
You may want to remove the round interior screen to see better. There is a small lip on the edge of the screen. Gently, but strongly, pull it straight down. It may seem like it will break, but won't. You can then remove the fan blades themselves held on with just one screw. This should give you plenty of access to diagnose the problem.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
Is the crank screw loose and in need of tightening?T@B trip wherever
New surprises everyday
See beautiful world1 -
I agree with your suggestion. Ours came loose after the first month. I went to the trouble to remove the screen, etc, before realizing all I needed to do was to tighten the screw in the handle!T@B: 2018 320-CS Max
TV: 2017 Toyota Highlander0 -
To alleviate my head banging that knob, I removed the screw and now keep the knob velcro'd nearby. To open or close, you just hold the knob tightly pushed in, and turn.
Agree, the OP probably has the lock engaged.
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6200 -
Y’all are good. While bbqing, I asked my wife for a Phillips screwdriver. I invited her in to help me fix the vent. Job complete. Thanks to all.2
- 964 Air Conditioning & Refrigeration
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 920 Tips & Tricks
