Currently, when we reach a destination, we reach into our TV and locate the odds and ends needed. ( the ball leveler, wheel locks, hitch lock, yellow stabilizer pads, jack wheel). Now... I was thinking.... How about putting all of these items in one easy to get to space. Make it well strapped on of course, and easy to put on and take off. I can’t think that these items would affect my tongue weight... I took a picture with a storage box in the location. This isn’t the one I would use, but I’d have to find one to fit a bal leveler.
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
J.D. & Sue
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
A pickup truck is light in the rear when unloaded. The first couple hundred pounds you add, just starts to balance out your front / rear weight balance.
My Canyon rides much nicer with 200lb in the bed than when empty.
I have my spare tire relocated to the tongue and it weighs out at just over 200lbs. It pulls fine with my Nissan Frontier V6.
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
I've carted two kayaks thousands of miles held to the roof of my truck cap with ratcheting straps. They are strong and can be easily snugged up if they stretch a little under use.
What make is the box that you are using? Where did you source it from? Thanks, Ray
Huntington LI
2017 T@B Outback
TV 2012 Nissan Frontier
Tehachapi, CA
Everybody's loading situation is different, so the only way to know how something affects your is to weigh your own trailer tongue with the camper packed for your usual travel conditions.
2017 T@B Outback
Tehachapi, CA
The actual difference being a function of several factors, including distance from the fulcrum. However, like you, I wouldn't think too much about it when I could just measure the tongue weight with a scale. I think the rule of thumb is to shoot for 10-15% of the loaded trailer weight.
T@bbey Road
Appleton, WI
As per my previous post, just be sure you somehow prevent that strap from creeping forward on the V-shaped trailer tongue and allowing the whole assembly to loosen up. I have visions of expensive camping equipment being "redistributed" along the side of a bumpy road! :-0
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Rural Liberty Hill, TX, near Austin
Wolfpack by frontrunner
T@bbey Road
Appleton, WI
I put my battery in today. The cover was the big problem.
Putting my bikes on. My wheel mount is temporarily off. Time to weigh. Hope wheel can return
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
