All users please be aware that the forum will switch to the new format this weekend (May 2-3 2026). You will see some changes in font and color and location of posts but basic functions should remain the same. Please post to the Help category if you experience issues.
Thanks
qhumberd
Moderator
Small and cheaper power screwdriver for the stabilizer jack
Not wanting to store the standard long jack handle I researched what it would take torque wise to operate them.  What I found was that the cheapest $30 Ryobi screwdriver, HP44L, had 45 in lb of torque.  With the charger and socket it weighs around 1 pound.  I tried using a 3D printed socket but it snapped at the first attempt so I ended up buying a 17mm deep socket cutting the hex part off with an abrasive chop saw and then putting a slot in the end with the same saw.  The ID of 16.3mm seems to be a good fit on the screw.  It ran on the 200 rpm setting, not exactly lightning fast, but a lot quicker and easier to handle.  A lot more places to stow this.
Chris P
2018 T@B 320 S built with Outback axle and wheels. TV 2006 BMW X3 White Manual Trans
