Small and cheaper power screwdriver for the stabilizer jack
BcsTractor
Member Posts: 8
Not wanting to store the standard long jack handle I researched what it would take torque wise to operate them. What I found was that the cheapest $30 Ryobi screwdriver, HP44L, had 45 in lb of torque. With the charger and socket it weighs around 1 pound. I tried using a 3D printed socket but it snapped at the first attempt so I ended up buying a 17mm deep socket cutting the hex part off with an abrasive chop saw and then putting a slot in the end with the same saw. The ID of 16.3mm seems to be a good fit on the screw. It ran on the 200 rpm setting, not exactly lightning fast, but a lot quicker and easier to handle. A lot more places to stow this.Chris P
2018 T@B 320 S built with Outback axle and wheels. TV 2006 BMW X3 White Manual Trans
4
Great idea. I get what you did where you cut the slot but I'm not quite sure what you mean about cutting off the hex part.
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado0 -
$30 ain't bad.2016 T@b 320 CS-S - 2018 GMC Sierra - St. Catharines, Ontario, Canada0
Newell - the first part of the deep socket is the 17mm hex section which would normally work on a 17mm nut. You don't need to cut it off but I liked the idea of less weight and better location on the jack leadscrew. In the chop saw it is a very easy cut to make.
2018 T@B 320 S built with Outback axle and wheels. TV 2006 BMW X3 White Manual Trans0 -
For those of us who are unable to modify a drill bit (me), I bought this:
https://www.amazon.com/gp/product/B00Q6ISG4M/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I am really liking the ease of using my cordless drill!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
I wonder if it's available anywhere besides Amazon.
We got ours at CW.John, Judi, Guinness & OD in PDX
eTrailer carries a similar item: https://www.etrailer.com/Accessories-and-Parts/Ultra-Fab-Products/UF48-979071.htmlnewell said:I wonder if it's available anywhere besides Amazon.Downers Grove, IL
2017 T@B 320S Max, Blue and Silver -- "The Blueb@rry"0 -
Thanks. I just can't support Amazon.
