Lund 9436T
Estancio
Member Posts: 243
Some of you use this Lund 9436T box on your T@B to replace the plastic tongue box. I want to do the same, but according to the manufacturer, the inside dimensions of this item is only 17". So how do you manage to get the Propane Tank to fit?
Stancil Campbell
2011 T@B
Rockingham, NC
2011 T@B
Rockingham, NC
I believe the one I got this model http://origin-www.gcp-prod.homedepot.com/p/Lund-36-in-Aluminum-Flush-Mount-Truck-Tool-Box-9436T/100592776?MERCH=REC-_-PIPHorizontal1_rr-_-203783400-_-100592776-_-N
Depth (in.) 20.5 inProduct Height (in.) 18.5 inProduct Width (in.) 36.75 in
Because to the shape of the propane bottle, the highest point of the propane tank goes past the obstruction that you mentioned and allows the lid to shut nicely.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0 -
Thanks....Stancil Campbell
2011 T@B
Rockingham, NC
Do you have the dual-battery setup in there? How hard was it to mount? My LP cover is busted and I'm assessing my options.dsatwork said:I believe the one I got this model http://origin-www.gcp-prod.homedepot.com/p/Lund-36-in-Aluminum-Flush-Mount-Truck-Tool-Box-9436T/100592776?MERCH=REC-_-PIPHorizontal1_rr-_-203783400-_-100592776-_-N
Because to the shape of the propane bottle, the highest point of the propane tank goes past the obstruction that you mentioned and allows the lid to shut nicely.San Francisco Bay Area
2015 Toyota Tacoma PreRunner Double Cab0 -
I was thinking of adding a box but was concerned that they don’t have enough airflow
Does this box allow airflow or is it sealed?
You would have to cut vents into it for the propane.lino said:I was thinking of adding a box but was concerned that they don’t have enough airflow
Does this box allow airflow or is it sealed?San Francisco Bay Area
Thanks for the quick response Marceline0
Yes six 2" vents across the bottom for propane and one in the middle and one on top for access to the electrical and hoses. There is a lund box thread with pics and details. http://tab-rv.vanillaforums.com/discussion/1127/lund-box#latest
Keep in mind that I use AGM batteries, although there may be plenty of venting for batteries, the batteries were not taken into consideration in my design per se.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0 -
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
