New Trailer Jack Wheel Conversion
It maybe a matter of opinion, but I believe it is.TerryV6 said:
Is this kind of tire better than the original?- Hash T@B Fun
These three wheel are all the same. The middle one is just an older one.Dalehelman said:
Up grade thanks to trikepete.Dalehelman said:Your project got me thinking. I also hate those cheep hard plastic wheels. The pneumatic was not quite right for my need either. I did find a 6" direct replacement hard rubber actually poly wheel with ball bearing axel. Thanks your project helped be find an answer to a problem I did not even know I had.
https://m.harborfreight.com/6-in-rubber-heavy-duty-rigid-caster-61647.html- Hash T@B Fun
@Dalehelman, How long a bolt did it require for the install of all 3 wheels! Nyloc nut also?
(Might have to get a temporary lift on my Harbor Freight restriction!
Would sure make pushin' the T@B back beside the garage a LOT easier on the gravel!2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
I saw the blue ones at Harbor Freight and they are rated at 350 pounds. I wonder what the original is rated at. Then there was the no-flat pneumatic, but only rated for (250lbs). What is the advantage of the 3 wheels? Also does one type roll that much better?Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0 -
These particular wheels have ball bearings. By spreading out the load footprint they are less likely to dig in when turning on soft surfaces.
- Hash T@B Fun
Is THIS what you're looking for?RedDoorGals said:Folks: I'm looking for reference item #'s or sources for any of the solid rubber "extra" 6" wheels. T
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
