T@b 400 front bed size
BigGrover
Member Posts: 450
Can anyone tell me what the dimensions are dinette front bed conversion? I have heard it is pretty short. We are thinking about getting a 2018 model but don't have a local dealer.
BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Central Alabama
I am 5’ 7” and can stretch out in the dinette bed. If I angled across it a bit, could buy a few more inches. It is surprisingly comfortable. Cheers.2018 T@B 400 Sw@llowt@il - 2015 Highlander - Dunedin, Florida
"Not all that wander are lost..." J. R. R. Tolkien
@BigGrover
The dinette bed is the same length as the bed in the back-just shy of 80" if you remove the cushions and do not have anything in the storage area under the window on the driver's side and sleep with your head on the door side. Note that the seat cushion on the driver's side are wider than on the passenger's side giving you an irregularly shaped but comfortably wide single bed.
Hope this helps!Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 T@B 400 -
Thanks much, just needed to make sure my 5'11" tall son could use it. He goes with us sometimes.BigGrover
Central Alabama -
The 'Click to enlarge' link isn't working here: https://tab.nucamprv.com/tab-400-floor-plan/
However, if you zoom in it indicates 74" x 31-39" for the dinette bed (with some gaps on interior side) while the main bed is 79" x 58".2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow) -
Thanks Tabber, today I wdnt to the website and they apparently fixed the isdue because it showdd a shaded area for the front bed with all the dimensions!BigGrover
Central Alabama -
Ah yes. Nicely fixed and easy to read now.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
