jhouston
Member Posts: 24
Anyone know where the location is for the solar panel plug in might be? I was told it was solar prepped. Also would a Honda 2000 watt generator be able to power the Alde System and/or A/C unit? Thank you in advance!
If you purchased the built-in, factory installed solar panels, they should already be wired from the factory.
Yes, others have said the Honda 2000 will power the Alde and A/C.
The Alde with water heater is a miser on propane, so you might consider using the propane for the Alde and fridge when you don’t have an electric supplied campsite.
@Verna @pthomas745 Thanks so much! This will be my first rv with the Alde heat system. I understand it's radiant heat. So for its operation it only requires propane and battery? I won't need shore line power or 110? My last 2 campers had a blower for the heating system so it required shore power.
However, if you do have shore power, you can save your propane and run the unit entirely on electricity as it also has two 950W electric heating elements.
I just want to give you a heads up on the radiant heat. I knew that I could feel the heat on the floor coming from the benches from the walk through with the dealer. However, I did not realize that the heat comes up along the back wall there the hinged shelf under the cabinets is. I had put basket all along that shelf, which blocked the heat. Fortunately figured it out after a bit one stormy night. Now when I use the heat, I move the four baskets to the kitchen counter.
@Tammara thank you! I'm pretty excited about the T@B. Thanks for the tip! I appreciate your insight!
