Towing Tab
Mare
Mare Member Posts: 2
What kind of cars can tow a tab?
  • jgram2
    jgram2 Member Posts: 1,522
    @Mare Hi Mare! We need to know which T@B model you're interested in. There are many and they vary quite a lot in size and weight.
  • ericnliz
    ericnliz Member Posts: 4,437
    @Mare, Lots of posts here about that very subject. Personally though... a vehicle that exceeds the towing capacity required for the model you're interested in, AND a hitch that exceeds the capacity for the tongue weight with a seven pin port for both brakes & charging. A vehicle with a minimum of a V6 motor with a transmission cooler, especially if you're headed to mountainous areas. Just a personal opinion from someone that does a lot of boondock campin'. :)
  • rkj__
    rkj__ Member Posts: 641
    edited December 2017
    Generally speaking, most vehicles that are offered from the dealer with a tow package (not just an aftermarket installed trailer hitch), can often tow a T@b.  A tow package often includes a larger engine, a suitable transmission that has sufficient cooling, in addition to the trailer hitch and wiring.  There are many exceptions to any general statement on the subject though.
    No:
    Most sedans and hatchbacks
    Sports cars
    Sometimes:
    Midsize crossovers and SUVs, if properly equipped
    Yes:
    Most Minivans and large crossovers
    Body on frame SUVs, vans, and pickup trucks
    Honda and Toyota minivans, too.
  • xbooooo
    xbooooo Member Posts: 33
