In trouble-shooting my lack of heating on propane (HW works OK), I’ve hooked up the T@B to shore power to see if it’s the glycol circulating pump. After 30 minutes it seems to be working and circulating fine. However, I did notice the “red knob” on the circ pump is set at its lowest setting (1)...is that standard? Why not set it higher for faster heating?
J.D. & Sue
1 ·
J.D. & Sue
@Verna, curiosity question: Have you actually heard the pump increase in speed if you try to turn the digital Alde setting up higher than 2? The only time I've been able to increase (and hear it increase) the pump speed is by manually turning the dial on the pump itself.
https://tab-rv.vanillacommunity.com/discussion/5716/alde-troubles
J.D. & Sue
Looks like ours is set to "1", but this was perfectly adequate on a couple of nights in the upper 30's, just by keeping the thermostat set to around 68 to 70. We've been very impressed with the Alde's ability to keep us warm. It sure beats the Army days I remember sleeping on the cold hard ground with nothing but a sleeping bag & waking up to everything covered by frost.
( Must not have had enough , I REALLY do know better! )
