I have a 2017 Tab Outback. I winterized it and then thought I would try keeping some heat in it for the winter. I just hooked up to shore power and turned the thermostat down to lowest setting (41). I also have a meter that just plugs into the outlet so I can see how much that item is costing me. I know Northern Michigan has not begun to see cold weather yet but the way I calculate the cost I believe it might run maybe 15.00 to 20.00 for the coldest months. When the sun comes out it will warm up inside to around 50. My idea in doing this is to keep things at above freezing which should help with moisture, things shrinking and expanding etc. I also pull the battery and keep it hooked up to a battery tender. Has anyone ever tried this and have comments.
2017 Outback, TV is now a 2018 Ram Eco Diesel
