How long does full propane tank typically last?
Are there any typical propane usage guidelines?  We camped this summer and fall with our T@B-CS (no extra S).  We haven't boondocked yet, so typically use electricity for the Alde.  Since our fridge is electric-only, that means cooking is almost the only use for propane.
We did camp in 25 degrees in November and needed propane for our Alde.  Our inexpensive in-line propane gauge, at the tank, indicated we were somewhere less than 1/2 full.  Since previously we used so little propane, we were paranoid of running out of heat in the night....   After the trip, I pulled the tank out and sloshing it around, it felt over 1/2 full.  Measuring it on our bathroom scale was 30#.  Calculating a full tank: 15# + (80% 20#) = 31 lbs.
So we do know the inexpensive in-line gauges are not very accurate.
How much mileage do others get on their propane?
I appreciate that Verna keeps an extra propane tank in her truck, but at the rate we seem to be using propane, an extra disposable cylinder might be all that we need to carry.
Thoughts?
T@B: 2018 320-CS Max
TV: 2017 Toyota Highlander
  • LSkrabutLSkrabut Member Posts: 136
    Take a look at the handle ring on top of your tank, the weight should be stamped on it. I would guess the empty tank is more around 17-18 lbs. I just topped mine up, it's weight empty was 18.6 stamped, after 6 days RV park camping and some propane heat checking out the ALDE, I used 1 gallon, now the tank weigh in at 38.8, 20.2 lbs for a full tank.
    Utah Driven
    2019 T@B 400 (Ex 2018 400)
    2015 MB GLK 250 Diesel
    2018 GMC Canyon Denali Duramax CCSB
    BTW, I like using a digital luggage scale (around  $10 online) to check how much propane is in the tank, 4 bs per gallon. ):
    Utah Driven
  • mammabear34mammabear34 Member Posts: 5
    wow this is super smart !  I never would have thought of doing this !
    Paula & 2 yr old boy & a couple of 4-legged kids along for the ride.
    Vancouver, WA (near Portland OR)
    2015 T@B 320 S
    2016 Kia Sorento V6 AWD
  • ScottGScottG Administrator Posts: 5,623
    edited January 2018
    U-Haul sells a tank with an integrated gauge operated by an internal float. It works great, and at $30 it's the best deal going. I picked up one based on a tip from this forum, and will replace my older tank with another when it expires.
    $30? Excellent. I needed a new tank!
