I am looking at getting the Tab400 and towing it with a 2017 Honda Ridgeline. Does anyone have any experience on how this combination would work? Do you see the need for a weight distribution hitch? Does the rear sag much? I hear the suspension is pretty tight and sag is minimal but would like to hear from someone in the real world.
0 ·
We generally tow with out cruise control engaged. Typically we run at 60-70 Mph. I have had it up to 80 with no sway. I use a Tekshoma P3 brake mounted with velcro under the driver side seat heat switch. The added plug from e trailer reached the coupling under the left side of the dash, no drilling no holes. MPG drops avg. 40%. The truck and trailer combination work and look very good together.
Huntington LI
