With the extra height and weight of the Outback model does anyone feel it's a more difficult unit to tow? I can get a pretty good deal on a Outback but I think it's close to 9ft tall? Seems like on fuel and wind resistance that extra height and weight would make it more difficult to tow? My vehicle has a tow package and 5,000 pound recemendation. My garage is 7ft 9 inches due to decorative trim so I will need to purchase a outside storage unit either way.
0 ·
Linden, VA
2016 T@B Q Max Outback Package - 2015 Toyota Tacoma TRD Off Road
Shenandoah Valley T@BBERS
Sounds like you are having classic trailer sway.
You should confirm your T@B tongue weight is in the correct range.
And you might consider adding an anti-sway bar between the FJ and the T@B. There are many types / price point options for sway bars.
While having a sway bar never hurts, posting here suggest the need for one varies widely with different tow vehicle - trailer combinations.
Adventures: 51 Nights: 322 Towing Miles 41,200+
Confirm your ball height is correct for an Outback
Alan & Patty
Southern Az
Gail & John
2019 Ford F-150 3.5L Ecoboost with Long Bed
Don't reduce tire pressure. Make sure Tow Vehicle (TV) and T@B tire pressure are at recommended level or above without exceeding the tire maximum pressure rating (marked on sidewall).
Why? Tire can carry more load at higher pressure levels. TV rating for GVW and CGVW are based on tires at recommended pressure. While camping most likely your TV is at or very near it's rated GVW, same for your T@B.
Note: While increasing tire pressure increases the tire load carrying ability you must still keep the TV and T@B maximum load at or below their rating GVW.
