2007 T@B
Rockford, IL
Really? Wow? I had already drawn up plans to remake the support base in the LP compartment inorder to move the LP tank further over to the side in order to mount the two batteries together on the other side. I like your idea. The propane connection attached to the T@B, did you have to move it to one side?Lisa33 said:Yes, you are correct as John said. I also have two Trojan T-105 batteries along with 300 watts of solar. Best upgrade by far! I put the two T-105 in the LP cover by moving the propane to the front center and mounting the batteries behind it on either side at a bit of an angle.
I have decided not to use battery boxes on my upcoming conversion. The reason being is that I plan on storing nothing else in the compartment, so much like under a car hood the battery needs no cover other than the top of the compartment.ChanW said:Lisa, did you end up not using battery boxes?
