Storing the T@B - sticking your tongue out
gregndeb
Member Posts: 33
We managed to get our T@B and 2 cars to fit in our 2-car garage. The only problem is the T@B tongue sticks out the side access door of our garage.
I did talk to a hitch dealer about getting a hinged tongue, similar to what some boat trailers have. "Not feasible" is the short answer. The "A-Frame" tongue, the light gauge of metal, etc. all work against that type of solution. (It could be possible, but it would pretty much require putting a new, heavy-duty frame under the whole trailer. Not pretty or cheap!)
I did want to see if anyone has tried it with a T@B, just to be sure.
The current plan is to have a support under the body, near the tongue. That part would stay in the garage. I could then remove the hitch jack, or get a removable one. Then I'll just need to modify the side door to have a "bump-out" to enclose the entire tongue and hitch. Said differently, a regular door with a giant wart on it.
Has anyone else done a fun storage project like this? Right now I just have a foam panel over the door opening with wood at the bottom to keep critters out. It's ugly, but it is nice not to scrape my car windows this winter.....
T@B: 2018 320-CS Max
TV: 2017 Toyota Highlander
Not a wart-a vestibule! What a good idea!John, Judi, Guinness & OD in PDX
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
