Holding tank odor revisited
Dalehelman
Member Posts: 2,414
Just a reminder to old and new T@B wet bath owners. If you experience a sudden increase in holding tank odor. It is most likely caused by the water evaporating in one of the two “P” traps. Either the sink or the shower. Just add about 12oz of water to each drain problem solved.
- Hash T@B Fun
2
Thanks @Dalehelman! So far I haven't run into this, but it's good to know it's an easy fix!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
@Dalehelman -We had that happen! Thanks for the reminder for folks.2016 T@B CS-S silver with white trim and WSU themed
@Dalehelman thanks for the reminder as we have been dealing with this issue off and on for a while now. @Sandiegogal are you listening?2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.1
If adding water to the P traps does not help, you can get a grey tank deodorizer. I have never needed it but it is good to know and might not be a bad move for the last outing of the season.dsatwork said:@Dalehelman thanks for the reminder as we have been dealing with this issue off and on for a while now. @Sandiegogal are you listening?2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Since the black water and the gray water share the same vent system. Black water oder can escape through “P” traps.
- Hash T@B Fun
So far, we haven’t had the “issue.” Partly because I like to take at least one shower while we r out and two the sink I said always used. I also sprinkle a little tank enzymes down the shower Drain while tending to the blank tank. Has become my protocol against stank!TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
We throw a flat flimsy drain cover over our shower drain when not in use. The thinking is that it will reduce potential "P" trap evaporation and prevent air/odor backflow.2017 T@B Max S (Silver-Silver), TV 2017 Jeep Grand Cherokee Trailhawk0
It’s possible that just the bouncing and pitching of the trailer going down the road. The water level in the traps could allow fumes to escape.
- Hash T@B Fun
2
- 30 "FOR SALE" - New/Used Trailers
