Custom Cabinets for Solo Travelers
Had these built by a local shop for $940.  VERY happy with the result!  They can be removed and will fit through the door.  Did not get a chance to weigh them before the install.
Cheapie child safety latches for now.  They work great keeping the drawers closed during travel, so will go with a more permanent type soon.
This unit contains a small microwave on a slide-out tray:
It also houses a BluRay player and receiver for the Dish satellite TV.  Will get rid of the Lagun table mount.
The hole in the white shelf is for a pin to secure the microwave during travel. Also one on the other side.
Magnetic door latches keep the doors secure while traveling.  I simply plug in the microwave to either the 110V shore power outlet or inverter outlet when boondocking.  I also extended the in-line fuse for the carbon monoxide detector so it is accessible in the Alde cabinet.
Small table for eating while watching TV.  The hole in the side is for a pin to secure the drawer during travel.
The shelf is adjustable.  Using it for shoes right now.
