Toilet Paper Holder?
JeffGeb
Member Posts: 11
Where do people keep their toilet paper? Have a 320 CS-S. Is there a good place to screw a holder into the wall?
Does anyone have a photo of the new standard toilet paper holder being installed by the factory? Jeff - I use a Costco plastic nut container. The TP fits inside perfectly.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
The good old Folgers container works just fine! (Makes 'ya smell coffee fresh to boot!)
Eric aka: Lone Wolf1 -
I keep ours in a Tupperware container. A lot of people use a large Folgers plastic tub.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
How do they attach that new TP holder?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Found this online - a 2018 model at a local dealer:
The location would probably bump my right knee, so I'll keep the Costco Nut Jar holder.
Looks like this: https://www.westmarine.com/buy/sail-systems--surface-mounted-covered-toilet-tissue-holder--176800Tabaz said:Found this online - a 2018 model at a local dealer:
I’m really happy with my holder, and the price was right! I love that there isn’t a permanently mounted holder, one less thing to bump into. It also does not unroll when traveling. Lately I’ve been looping it over the hot and cold water handles, freeing up those two hooks for other stuff.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
@Homebodyatheart...that’s the simplest, most elegant solution to the TP issue yet. And if you loop it over the water faucet handles as you suggested, you’ll be reminded to move the TP to a dry place when showering. Thanks for the suggestion.
2017 T@B Max-S, silver & silver, towed by a Titanium Silver 2018 Kia Sorento AWD V-6, Twin Cities MN0 -
@GibW you’re welcome! Quick, cheap, and easy... my favorite thing! The green pad behind it is one of those microfiber dish drainer pads. I use it for a bathmat just outside the shower door. Found it somewhere on clearance for $1, and it dries quickly.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
--Meg
Mostly A Solo RV Chick
T@B Outback
Jeep Grand Cherokee0
