Grey water valve pic
SGH0004
Member Posts: 62
We had the misfortune of knocking off the grey water hookup in WA a few months back. Now we are getting ready for 2018 camping season & wanting to get this project out of the way. The problem is now that it has been so long, I can't remember for the life of me how the piping was run. If possible, could someone take a few pics of their grey water outlet so I will know what all parts I need & how I need to run everything? Thanks for the help.
Do you have the separate black and grey water outlets?
And/or which T@B model and year do you have?John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
Since you have already removed the gray water dump valve. I would do this.
- Hash T@B Fun
@Dalehelman. Thanks for the reply. That's a great idea. Can you send me a pic from the back side of the grey water side as well? What size is that 2 into 1? 1 1/2" & 3"? Where did you get the plumbing material? Did you have to do anything else besides 45 (?) into the 2 in 1?
My T@b is a 2015 model & it came with seperate black/grey valves.
Here is a list of all the parts needed. You will be reusing both gate valves. Once you have all of the parts assembly is fairly straightforward from the above pictures. The 22 1/2* elbow address's the frame clearance issue. The rubber elbow is not a perfect fit but that is why it is rubber. Once completed the discharge end is know lower than the original gray water discharge. I have found that the prices for the RV parts are are cheaper at my local RV parts store.3" abs 90 degree elbow with an 1 1/2 take out HD $12.43(3 in. x 3 in. x 1-1/2 in. ABS DWV 90 Degree Hub x Hub x Hub Elbow with Low Heel)Total $41.14 $35.36 (w/ 2 HD)RV PARTS STORE (For the gate valves)Total $19.69Total for parts $60.83 Total $55.05---------------------------- Hash T@B Fun
I too have a 2015 T@B Max S which has broken off the grey water discharge in front of the gate valve. Can someone please post a picture of the original configuration? I have no desire to combine the black and grey water discharge, I just want to fix the gray water discharge.2015 T@B M@X-S, 2017 Ford F150 2.7L V6 Turbo
Chesterfield, VA
- 919 Introductions
- 74 Teardrop Groups & Links
