All users please be aware that the forum will switch to the new format this weekend (May 2-3 2026). You will see some changes in font and color and location of posts but basic functions should remain the same. Please post to the Help category if you experience issues.
Thanks
qhumberd
Moderator
Grey water valve pic
We had the misfortune of knocking off the grey water hookup in WA a few months back.  Now we are getting ready for 2018 camping season & wanting to get this project out of the way. The problem is now that it has been so long, I can't remember for the life of me how the piping was run.  If possible, could someone take a few pics of their grey water outlet so I will know what all parts I need & how I need to run everything?  Thanks for the help.
  • xbooooo
    xbooooo Member Posts: 33
    Do you have the separate black and grey water outlets?
  • jgram2
    jgram2 Member Posts: 1,522
    And/or which T@B model and year do you have?
  • Dalehelman
    Since you have already removed the gray water dump valve. I would do this.
    1. Hash  T@B Fun
  • SGH0004
    SGH0004 Member Posts: 62
    @Dalehelman.  Thanks for the reply.  That's a great idea.  Can you send me a pic from the back side of the grey water side as well?  What size is that 2 into 1?  1 1/2" & 3"? Where did you get the plumbing material?   Did you have to do anything else besides 45 (?) into the 2 in 1?
  • SGH0004
    My T@b is a 2015 model & it came with seperate black/grey valves.
  • Dalehelman
    edited February 2018
    Here is a list of all the parts needed. You will be reusing both gate valves. Once you have all of the parts assembly is fairly straightforward from the above pictures.  The 22 1/2* elbow address's the frame clearance issue. The rubber elbow is not a perfect fit but that is why it is rubber. Once completed the discharge end is know lower than the original gray water discharge. I have found that the prices  for the RV parts are are cheaper at my local RV parts store.
    3" abs 22 1/2 degree elbow HD  $9.24 AMZN  $7.68
    3" abs 90 degree elbow with an 1 1/2 take out  HD   $12.43
      (3 in. x 3 in. x 1-1/2 in. ABS DWV 90 Degree Hub x Hub x Hub Elbow with Low Heel)
    1 1/2" rubber elbow with hose clamps HD  $6.84
    2ea. 3"  diameter x 2" wide black abs pipe. HD   $7.75 for 2’
    Small can of abs cement  HD   $4.88 8oz AMZN  $3.55 4oz
    Total $41.14     $35.36 (w/ 2 HD)
    RV PARTS STORE (For the gate valves)
    3" bayonet slip fit   AMZN   $6.88
    3" bristol spigot end AMZN   $7.75
    1 1/2 Bristol spigot end AMZN   $5.06
        Total $19.69
    Total for parts     $60.83 Total $55.05
    1. Hash  T@B Fun
  • leenscottfl
    leenscottfl Member Posts: 254
    Great pics and shopping list. Thanks a lot for sharing Dalehelman. Heading to HD this AM!
  • RVABuff
    RVABuff Member Posts: 15
    I too have a 2015 T@B Max S which has broken off the grey water discharge in front of the gate valve.  Can someone please post a picture of the original configuration?  I have no desire to combine the black and grey water discharge, I just want to fix the gray water discharge.
    2015 T@B M@X-S, 2017 Ford F150 2.7L V6 Turbo
    Chesterfield, VA
