Toilet fills with water when not in use
ChrisandAlexis
Member Posts: 120
Alexis and I just got back from a camping trip where we had a problem with the toilet in our TAB fill with water. After flushing and completely emptying the toilet, we would check on it and it would have water in it after a few hours. We could see a small stream come from the water outlet that is used to fill the toilet with water to flush. Any ideas on how I can fix this myself or do I have to take it into the dealer we bought it from. We have a month left on the 1 year warranty.
Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner
You have a defective water control valve on your toilet. Your dealer should be able to replace it for you, under warranty. Here’s how mine was diagnosed and repaired. http://tab-rv.vanillaforums.com/discussion/3901/toilet-issue/p1Verna, Columbus, IN
Thanks @Verna for the quick reply. It doesn't look like something I would like to tackle myself.Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner1
It is definitely the water control valve. The last time I had the problem. I installed a water shut off valve where the water line comes through the wall. That way in the future I can shut off the water to the toilet with out going outside. Just like any residential toilet.
- Hash T@B Fun
2 -
Dale, I don’t have our Tab to look at this. Is the hose visible with the factory installation of the toilet? Do you need to pull the toilet to add the shut off?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Verna, I guess you must have had the hose before your repair. How else would you receive fresh water!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
NoSAM said:Dale, I don’t have our Tab to look at this. Is the hose visible with the factory installation of the toilet? Do you need to pull the toilet to add the shut off?- Hash T@B Fun
- 427 Service/Maintenance & Recall Notices
