Hi, I just bought two Garmin backup cameras (one main cam and one add-on). One is for my tow vehicle, and the other one I'm installing on the back of the T@B. I'm wiring the main cam to my Jeep reverse lights so the cam is only visible when I go in reverse. However, i want to wire the T@B "add-on" camera to be on all the time so I can see behind me while driving. I know I just need to wire it into the constant 12 volt power source in the camper (which will be powered by the TV while towing). My question is, where on the converter would I attach the two tiny power wires (red/black) to get constant power to the cam? Since the camper is still tucked in for the winter, I haven't been able to go in there and look at potential connection sites, and honestly, I have NEVER even really looked at the converter other than a glance. I thought I would first check with others to see if anyone else has wired in a back up camera on their T@B.
Thanks,
Robyn
0 ·
Maybe this link can help it shows how I sourced my 12v power for the back camera:
https://tab-rv.vanillaforums.com/discussion/comment/88548#Comment_88548
You might be able to use this simple inline power switch if your camera 12v feed is the "standard" connector:
https://smile.amazon.com/gp/product/B01D66D9PM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Good Luck!
Huntington LI
@robyn769 - I'm also in the process of wiring 12v power for a rearview cam. It'll mainly be used while driving, but I thought it would also be fun to use at camp from inside the trailer - which means I'll need to connect it to a constant 12v circuit (on a switch of course) instead of the license plate/tail light feed.
I already have a wiring path into the WFCO compartment thanks to my recent BMV-700 install, now I just need to decide which 12v circuit to tap into. @AldebaranJill's wiring diagram makes for a great starting point/reference.
FYI - I went with the SVTCAM SV-928WF Wireless Backup Camera which creates its own wifi hotspot that you can connect to with a smart phone or tablet. Seems promising so far but haven't fully tested yet.So if I power it into the tail lights, then I would just need to have my Jeep headlights turned on right? I guess that would work fine. So it wouldn't make sense then to try to wire it directly into the converter? I was trying to figure out where to wire it into so it gets power when my 7 pin connector is hooked to my running tow vehicle. I don't want to wire it all the way up front direct to the batteries. I wanted to tap in somewhere along the way. This is really making my brain smoke! I have VERY limited knowledge in wiring, but I did manage to successfully install a BVM-700 battery monitor all on my own!
How bright is the IR illumination? For example, would it be bright enough to illuminate backing into a campsite, if mounted up near the roof vent?
@ChanW - Still working on getting it set up and tested prior to a trip next week (Nebraska to see Sandhill Cranes). The phone app apparently has a screen capture feature, so if I have time I'll try to post some pix.
Current plan is to mount it somewhere on our Boondock's Yakima rack. Design is still fluid as I'm also prototyping a rack-mounted solar panel mod.
