Tonight I installed an accumulator tank in an attempt to quiet our noisy water pump in our 2014 S Max. After the install I tested the system and found the results mixed. The bummer is that the pump still makes the thumping sound but it does seems to be somewhat quieter now that the tank is installed. On the plus side, what I'm very pleased with is that the pump no longer makes the loud clanging sound just before it shuts off. Overall I'm pleased with the outcome. The tank is a SHURflo model 182-200. It was about $40. The photos below show how it connects to the pump and the rest of the system. About 15 minutes to install. Only dropped one screw down behind the wall.
2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota
1 ·
Footnote: I just noticed in the second photo from @Spruce1, the left pipe is wrapped with black foam insulation. Our 2018 Max did not have that from the factory, but that is what I think is key to noise reduction.
But, if I let the water level go below what the pump can pump out of the fresh water tank, the noise level goes back up to the original until the pump is totally primed, and then the noise level goes back down.
Just in case, it’s nice to have 5 gallons or so of fresh water in a jug, or jugs, ready to be transferred into the fresh water tank.
Minnesota
