Yet another table slat project
Rad
Member Posts: 516
We are heading off to Big Sur this weekend and since we did not like the big table and installed a small table we need to be able to set up a full size bed. Dragging in the big table to set up the bed is just not an option, we tried that.
As many others have done, I did the slat thing. I could not find matching Birch so I went with poplar. It comes pretty darn close to matching.
I went with stainless steel hardware.
I used pine 1x12's since they don't show.
A nice feature is that our table breaks down in seconds and stores under the bed slats when the bed is made up.
This is great! Thanks for posting.
Rad,
A couple of question. Where do you store the slats when not in use? Also, hard to tell from photo, is the passenger side cleat just above the warm air outlet slot? -
I have not decided where to store them, they do fit in the seat compartments.sabel said:Rad,
The heat slot is partially blocked; however, on mine the heat slot was already partially blocked by the wood frame behind it. I did not notice this until I started this project and got down at eye level with the slot. I may at some point remove my slat support on that side and trim about 3/8" off the bottom, or just enlarge the heat slot to get the max heat flow, unlike the factory set up. -
Quick pic to show how they fit in the passenger side rear under seat area. They also fit under the seat by the door; but, I use that one for things I need to access often so it is not an option for me. Also, when placed in the one by door nothing else can really fit in there with them.
Did you use wood screws to secure the rails to the plywood or install bolts through the rails and use nuts and washers inside the benches? Also in terms of the floor mounted post support, a similar question, did you use screws or bolts?Martin - Trailer name: James T@Berius Kirk
Size #10 Stainless steel wood screws, 1 1/2", for the slat supports with stainless steel finishing washers. Stainless steel screws for the table support. The floor made me nervous because it is just foam, not wood. I think the floor screws were 3/4 " and as beefy as would fit in the mount. I also made smaller pilot holes in the floor and filled them with non-adhesive silicon caulking then mounted the base. It is very solid, I'm pleased with it.mawebb said:Did you use wood screws to secure the rails to the plywood or install bolts through the rails and use nuts and washers inside the benches? Also in terms of the floor mounted post support, a similar question, did you use screws or bolts? -
The information and photos are extremely helpful. I am adding it to my list of projects for the T@B.Martin - Trailer name: James T@Berius Kirk
Very nice. I need to review your pole and its purchase as well as the screws.Judy and Mike - Central KY 2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 32
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
