Tab 400 electrical outlets
I am plugged into power and the only outlet that works is in the cuby by the bed. All others don't work. I had it plugged in a couple weeks ago and they all worked. Any idea why this is happening?
2018 Tab 400 towed by 2013 F150
Evanston Wyoming home
  • robpt
    robpt Member Posts: 90
    No tripped circuits?
    North Florida T@B 400 towed by a 2014 Nissan Frontier
  • sdenhof
    sdenhof Member Posts: 44
    I dont see any fuse issues
  • Dalehelman
    Look for a GFI that needs reset or possibly a circuit breaker. Fuses are only 12 volt circuits.
    1. Hash  T@B Fun
  • sdenhof
    the gfi near the sink and in the bath both have red light showing but not blinking. When I push reset nothig seems to happen???
  • Dalehelman
    Sounds like one of the breakers has tripped. It’s hard to tell sometimes. Switch all of them off and then back on. One of them will probably feel different, and that’s the one you are looking for. Double check your shore power.
    1. Hash  T@B Fun
  • sdenhof
    Got it fixed thanks everyone!
  • jgram2
    jgram2 Member Posts: 1,522
    @sdenhof was it a breaker? (For future reference!)
  • Dalehelman
    edited March 2018
    Thanks
    1. Hash  T@B Fun
  • sdenhof
    Actually it looks like I was just not pushing the reset on each outlet hard enough:)
  • jgram2
    That’s good to know too! Thanks!
  • jkjenn
    jkjenn Member Posts: 6,425
    Same thing happened to me!
  • Dalehelman
    To completely reset a circuit breaker you must switch it off first then back on. Not just switch to on
    1. Hash  T@B Fun
  • gooddogs74
    gooddogs74 Member Posts: 76
    My usb by the bed is not working, is this also controlled by the breaker?
    2018 T@b 400
  • Verna
    Verna Member Posts: 6,876
    The USB is 12V only. Look for a blown 12V fuse.
    But, most likely, the USB has a wiring malfunction or has gone bad. I have changed all but one of my USB ports to 12V ports because the USB ports are not lasting longer than 6 months. I paid $15 for a new one in December and I tossed it February. I’m using USB plug-in’s that have a longer life span than the USB ports.
    If you are under warranty, and If the USB is defective, contact your dealer first for replacement.
