Tab 400 electrical outlets
sdenhof
Member Posts: 43
I am plugged into power and the only outlet that works is in the cuby by the bed. All others don't work. I had it plugged in a couple weeks ago and they all worked. Any idea why this is happening?
2018 Tab 400 towed by 2013 F150
Evanston Wyoming home
No tripped circuits?North Florida T@B 400 towed by a 2014 Nissan Frontier
I dont see any fuse issues2018 Tab 400 towed by 2013 F150
Evanston Wyoming home -
Look for a GFI that needs reset or possibly a circuit breaker. Fuses are only 12 volt circuits.
- Hash T@B Fun
the gfi near the sink and in the bath both have red light showing but not blinking. When I push reset nothig seems to happen???2018 Tab 400 towed by 2013 F150
Sounds like one of the breakers has tripped. It’s hard to tell sometimes. Switch all of them off and then back on. One of them will probably feel different, and that’s the one you are looking for. Double check your shore power.sdenhof said:the gfi near the sink and in the bath both have red light showing but not blinking. When I push reset nothig seems to happen???- Hash T@B Fun
Got it fixed thanks everyone!2018 Tab 400 towed by 2013 F150
@sdenhof was it a breaker? (For future reference!)John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
- Hash T@B Fun
Actually it looks like I was just not pushing the reset on each outlet hard enough:)2018 Tab 400 towed by 2013 F150
That’s good to know too! Thanks!John, Judi, Guinness & OD in PDX
Same thing happened to me!sdenhof said:Actually it looks like I was just not pushing the reset on each outlet hard enough:)
To completely reset a circuit breaker you must switch it off first then back on. Not just switch to on
- Hash T@B Fun
My usb by the bed is not working, is this also controlled by the breaker?2018 T@b 400
The USB is 12V only. Look for a blown 12V fuse.
But, most likely, the USB has a wiring malfunction or has gone bad. I have changed all but one of my USB ports to 12V ports because the USB ports are not lasting longer than 6 months. I paid $15 for a new one in December and I tossed it February. I’m using USB plug-in’s that have a longer life span than the USB ports.
If you are under warranty, and If the USB is defective, contact your dealer first for replacement.Verna, Columbus, IN
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
