HELP! Side wall of T@B pulling away at door frame floor
dogmother
dogmother Member Posts: 14
Pretty much as described above. Just noticed "daylight" along the floor/wall join. See attached photos. Any suggestions on how to fix or where to take it to be fixed (Seattle area). This is a 2005 T@B that we have owned since 2007.
Diane & Murphy
2018 T@B 320-S towed by 1999 Chevy Suburban, Olympia WA
    MuttonChops Member Posts: 2,033
    Strange.  One RV Manufacturer I was strongly concerning before purchasing a T@B had a sales promotion point of:
    There was a gap between the side walls and floor to allow water to drain out if there was a major spill in the cabin.
    Now is that just SPIN or something to consider?
  • jkjenn
    jkjenn Member Posts: 6,424
    Oh, yikes! I am sorry to see that! The Dutchman made T@bs are constructed a little differently than the NuCamp T@bs. I would check the Yahoo group as there are a lot more DM T@b owners there. You could also call NuCamp to see if they have any dealers they work with in the area. That dealer could at least call NuCamp to consult, if needed. NuCamp does repair DM T@bs, but that is not convenient for you. I would seek that up to keep the critters out, for now.
  • Mouseketab
    Mouseketab Member Posts: 1,262
    Definitely get that to a dealer or the NuCamp factory for a fix. Unfortunately, you may have a cracked frame inside your floor which allows the floor to pull away from the sidewalls. Also the door is one of the worst places for water intrusion in the Dutchman T@Bs. I hate to say it, but your T@B is a 2005, time to give it a shiny new NuCamp floor. Also, check T@B Camping Trailers on FaceBook. There are many Dutchman owners there, that have replaced floors and repaired sidewall damage themselves.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • Mouseketab
    Another thing you can do to see how bad it is. Go inside the bench seats and cut out the vinyl floor.
    Carol
    MOUSE-KE-T@B
    Harvest, AL
  • irvingj
    irvingj Member Posts: 335
    BTDT. Check floor carefully; looks like the infamous Dutchmen T@B water intrusion/soft floor issue. See thread for same on this forum. It is fixable.
  • dogmother
    MANY thanks for your help!
