We took delivery of our 2018 320S in January and have been very pleased. We have used it on four outings, the last one for nearly two weeks. TV is a 2017 Toyota Highlander XLE with AWD (5,000-pound towing capacity with the AWD). Everything has worked well and thanks to reading this forum and the Facebook T@B forum (and a thorough walk-through from our dealer, Princess Craft), the learning curve was not that steep. On our last trip, we noticed our grey water tank was at 94 percent full. At that point, we were about 12 hours from leaving and hitting the dump station. We just tried not to let anything else go down the sink and did not shower. We had no issues and use the toilet several times that evening and the next morning. Then, as we were packing up, we noticed a small amount of water on the shower/toilet floor. We assume that grey water had backed up onto the shower floor, right? It was obvious (to us) that it was not from the black water tank because that would not have come up through the shower drain, plus there was no odor.
My question for those who know - why would we experience no backup overnight, yet have it appear even though no more water had been added to the grey tank. Any ideas what's going on here?
Side note - for those thinking about the indoor bathroom, it has worked out great for us. I was a little concerned, but it has been very handy in the middle of the night. The dump station trips are a non-event. It is a really easy process with virtually no foul odors, no spills and no direct contact with anything unpleasant.
                2018 T@B 320S. 2017 Toyota Highlander AWD
3 ·
I'd say that as you walk in your T@B, or as you may get things out of the front box or move stuff around inside, this will re-distribute the weight and the water level may slosh or rise up. Also, your stabilisers may sink into the ground as it gets more compact causing a slight level change that you wouldn't notice, but your tank might.
Like you said - luckily it's grey water and luckily it just goes into the shower pan!
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
It allows me to hook up a normal garden hose to the drain outlet. I often drain my grey tank (I don't have a black tank) into portable containers and then take those to a dump area. The grey tank is only 19 gallons, so even taking two or three gallons out of it reduces the level a good bit. These caps are really inexpensive and so handy!
