Want to DIY a small "suitcase" solar on our T@B 400
sunshine
Member Posts: 23
Dry camped this past weekend for the first time in our 400. Temps in the low 30's, Alde was AMAZING!, lights, water pump, radio, tv and even the smoke detector (over zealous bacon frying) worked flawlessly. Kept an eye on our digital volt meter for usage. Is there a "complete" set to do the solar thing, if so great, if not what do I need? I feel comfortable doing the install and MAY prefer that option after reading about the not so great experiences others have had with dealers. As always thanks in advance!!
2018 TAB400 - M@ry-Christine, White/Black, 2017 Chevy Silverado 2500HD, White
You have lots of options. Read this recent thread over for a start:
Towed by 2014 Touareg TDi -
The closest thing to a "complete set" would be a solar suitcase with controller. These typically include a folding stand-alone solar panel, an attached controller, and some means of connecting to your battery. They are pretty much plug and play. Zamp and Renogy are popular brands used by many here on the forum.
Of course, you certainly can buy individual components and configure your own system--but there's no quick answer on what you should get or how you should go about building it.
If you are new to solar, I would suggest the suitcase approach to start--they are easy to use, versatile, and can be modified and adapted to your needs as you figure out exactly what those needs are.
The attached photo is my DIY 200 watt solar suitcase. Weights 20 lbs. 50 ft. 8 gauge cable wired in series. Works great.
2007 T@B
Rockford, IL
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
