They won't make this an option until June, 2018, but my husband and I are seriously considering getting the axel/tire setup for rough roads and exploring off the beaten track. What are your experiences with the TAB 400 on rough roads as it exists with current setup?
0 ·
Depending on what you define as "rough roads and exploring off the beaten track" the T@B--while solidly built--is not really designed for this purpose.
Hopefully someone else can chime in here with some actual experience.
While the Boondock models and the pitched axle looks cool, that is all it is designed to be—cool looking and a bit higher to take those bumps slowly. I really can’t stress that this is a NOT an off-road “follow the Jeep” where ever it goes camper.
Personally, I would like the cool looking Boondock model....to look cool in the desert as I deploy my solar panels to Camp on BLM land with no one else around!
So from the start, the Trailer are not made for fast cruising baja style on dirt roads and trails. No protection, suspension, even if beafier, is to stiff and do not react well enough to simple drive fast on rough ground.
I do not know about the T@B, but the T@G version of the outback as bigger tire and matched with the pitch angle axle, gives it more ground clearance. But sill, no protection and a stiff ride that will shake a the trailer big time.
so if you druive slowly, and be carefull of clearance isues (specialy black water pipe under the T@B), you should be able to go many places.
remember that some people will stop for the vehicule, way before the trailer can be in problem. As for crossing a stream, I would walk it fisrt, and make sure that the water does not reach the floor. But other wise, yep, I would take it as far as possible.
A trailer can go pretty far, if you respect it. And if you are a hikker, than technically, you are not in a hurry.
Mandy Lee made a nice vid of where she take her T@B. You can see that the vid was accelerated in some bouncy spot, but still, bouncing might have been an issue, but ground clearance looks ok for her desert ride.
btw, I will be upgrading to an air bag suspension on ours. But that involves a lot of planing and building.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Some people here does not realy like the fact that some of us drive off road, but if there is something we learn while off roading, is driving at a speed that will alow us to go over obstacle w/o dammaging our rig (specially while overlanding cause you could be hundreads off miles from any help or parts, and to tie up everything in TV or trailer, to make sure that nothing can move and hit someone in the TV in case of accident or emergency vehicule, and in the trailer, so that the trailer and object will not be broken of dommage.
that can only be learn by experience, and responsable driving.
happy trails!
So the First question should be how much additional 'pitch' (ground clearance) would a Boondock Style 400 provide ?
Just looking at 320 Outback/Boondock units on the dealer lot vs. 400's my guess is the 400 is not pitched as much as a 320 Boondock . . . but that's ONLY a guess.
I selected a 320 S with the Outback/Boondock axle and tires instead of a full cosmetic package.
My goal is to drive on mostly primary forest service roads** but be able to get across those 50 feet to 75 yards of washout or ruts or . . . Am hopeful the 320 S can do.
My experience with Forest Service roads is that nearly all Trailheads are on a primary or maintained road. Never stopped at one that did not have a 2-wd Sedan parked . . . while most vehicles were Subaru's (not an off-road vehicle)
As @Haloo wrote, I wouldn't try taking it down anything too rough and would drive slowly on a washboard dirt road.
but a forest service road and desert road is not off road driving. Make shure you take wash out with a spotter and do it very slowly w/o dragging any part of the trailer.
But the longer the trailer, the harder it is to pass rougher area.
the only draw back, is that the tire are air up with nitrous, so ober time, you will loose it, but air as been in tire for more the a hundread years up till now, and air is compose of 70% nitrous anyway, it will not dammage the tires, just that you have to check them on a ruegular bassis, no matter what you use to inflate them.
so, just make. Sure you reinflate them when going back to speed on black top, cause they could heat up and also get uneven wear.
