FIXED
jritchey3
jritchey3 Member Posts: 16
edited September 2018 in Modifications & Upgrades
The lever on the original folding table in my 2007 T@B queen u dinette has broken and come completely off. Does anyone know where I can find a new  up/down lever?  Thanks for any info.
  • JustJohn
    JustJohn Member Posts: 171
    Call NuCamp first, they can probably help you. If it's the standard table used in later editions, someone on the forum may give you a table. Where are you located? I have the table out of my Outback I do not use.
  • jritchey3
    I appreciate the offer but I live in Arkansas.  The table sticker says TUV and has a German company name.
  • ChrisJ
    ChrisJ Member Posts: 12
    On a recent trip to Alaska and Yukon, our collapsible table (TUV) appeared to break, but I discovered on closer inspection after our trip that it had just come apart when 'someone' reefed on it the wrong way.  It is a 'clamshell' assembly, and just need to be in the correct orientation and the two halves slide together (a bit of a puzzle..). It now works just fine with a gentle push.
    2004 T@B
    Qualicum Beach, BC
  • jritchey3
    Thanks, I discovered the same thing.  All good now.
