FIXED
jritchey3
Member Posts: 16
The lever on the original folding table in my 2007 T@B queen u dinette has broken and come completely off. Does anyone know where I can find a new up/down lever? Thanks for any info.
Call NuCamp first, they can probably help you. If it's the standard table used in later editions, someone on the forum may give you a table. Where are you located? I have the table out of my Outback I do not use.2016 Outback.....North East N.C...... Former 2012 Silver Shadow0
I appreciate the offer but I live in Arkansas. The table sticker says TUV and has a German company name.0
On a recent trip to Alaska and Yukon, our collapsible table (TUV) appeared to break, but I discovered on closer inspection after our trip that it had just come apart when 'someone' reefed on it the wrong way. It is a 'clamshell' assembly, and just need to be in the correct orientation and the two halves slide together (a bit of a puzzle..). It now works just fine with a gentle push.2004 T@B
Qualicum Beach, BC1 -
Thanks, I discovered the same thing. All good now.0
- 422 Service/Maintenance & Recall Notices
