Assuming that a tow vehicle could easily handle the load, how much weight can you safely add to the T@B without overloading it?  And, if you add a lot of weight, would it be advisable to increase tire pressure if you're not already at maximum psi?  I'm not talking about hauling a load of pig iron, but maybe 200-300 lbs. of extra "stuff" inside the T@B.
Happy Trails Y'all
0 ·
Thanks, Norm. Makes sense, which is probably the reason I didn't think of it.
I checked the specs and found the axle rating to be 2900 according to LG. The heaviest T@B is somewhere around 1800. I wouldn't want to max it out, but a little added weight should be just fine.
Happy Trails Y'all
2014 T@B CS Maxx
Martha Lake, WA
