Our new 2018 T@B 320 S Norcold refrigerator exhaust vent reaches about 140 degrees when on medium electric setting and seems very hot to touch. Our model has both the intake and outtake vents next to the door. So, the door also gets hot if it's latched in the open position. We're just wondering if anyone else is having a similar issue with a very hot outtake exhaust vent while using the electric mode to cool the refrigerator
0 ·
ps. I tried unscrewing the black screw/tab things holding the vent on the outside so I could peer inside, but unscrewing doesn't do anything...how do the vents come off?
Thanks
Sold 2023 Tab 400
Sold 2018 T@B 320S
This is the inside of my vent with a screen and filter. To remove it, rotate the black clips at the top 90 degrees and tip the top out. The bottom is held in place by the white plastic feet along the lower edge. Once the top of the vent is rotated out, just lift up the vent to clear the bottom hooks from the opening in the sidewall.
