Clean surface with an alcohol wipe before use. I have yet to have these become unstuck even in hi heat
conditions. They can be removed with slow and I mean slow steady pull starting at one end. They can also be found at Home Depot.
https://www.amazon.com/dp/B00347A8GM/ref=cm_sw_r_em_api_i_c_bYH-Ab58AWVCG
I have had pretty much the same experience as you. Recently I have seen some comments that were negative. Just another option to avoid drilling holes.
3M Dual Lock https://www.amazon.com/dp/B00JHKTDMA/ref=cm_sw_r_cp_tai_i_rHg.Ab4HEH00Y
these are both the same product. Not exactly permanent but difficult to remove.
