Weight capacity of the stabilizer jacks.
Luckyj
Luckyj Posts: 286
edited May 2018 in Products and Accessories
Anyone knows what is the load capacity in lbs of the stabilizer jacks on a T@B?
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
  • Dalehelman
    Dalehelman Posts: 2,414
    @Luckyj
    1000 lb each
    1. Hash  T@B Fun
  • OpenSky
    OpenSky Posts: 30
    They are BAL 23007 jacks.   They are rated for 1000 lbs, but they can't lift anywhere near that, and the plane the screw and leg lie in must be perfectly vertical.   This means they can't carry that load unless the trailer is perfectly level.
    ScottG Posts: 5,687
    They are stabilizers--not really jacks in the true sense and should not be used for lifting purposes. The design does not allow for much leverage without excessive force.
    They can be used to make some very fine level adjustments if needed.
  • Luckyj
    Luckyj Posts: 286
    @ScottG thank you.
