Pump Problems
Yes, but 3 days of cavatating & pressurizing? I could see there being an air leak if it never pressurized, but it will...sometimes. If there is an intermittent air leak, where & what would cause it while sitting still? Frustrating....once back in the driveway I’ll delve deeper, for now just dealing with it....TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
I did not remove the pump, just a cover to expose the allen set screws that control the shut-off pressure.T@Balong said:Where is this adjustment located? Do we need to remove the pump in order to make the adjustment?
2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
RollingBnB said:
I did not remove the pump, just a cover to expose the allen set screws that control the shut-off pressure.T@Balong said:Where is this adjustment located? Do we need to remove the pump in order to make the adjustment?This link has information on adjusting Plus a youTube video . . .'18 320 S, pitched axle, 3020HE; PNW based
Adventures: 59 Nights: 411 Towing Miles 50,3501 -
Can someone please post a YouTube link for adjusting the SureFlow Water Pump on a 2019 NüCamp T@B 320 = = Thanks !0
@Footslogger - if it is a Shurflo pump, there is a link immediately above your post that explains the process as well as includes a YouTube video.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Thank you !!0
Here is another video about pump troubleshooting. At about six minutes there is an explanation of the adjustment set screw, and the method to get your pump running a bit more smoothly.
Towed by 2014 Touareg TDi0
- 143 Events & News
- 923 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
https://www.youtube.com/watch?v=bye7kO9cWxs&t=151s
