Frig clips
MaeMae Member Posts: 12
Has anyone tried the brackets that screw onto frig shelves to keep items from rolling around? Even with plastic containers I worry about the fins getting bent.
  • ScottGScottG Administrator Posts: 5,583
    @Mae, I'm not quite sure what you are referring to, but I don't see why they wouldn't work.
    I zip-tied a piece of plexi to my upper shelf to keep things from rolling off onto the fins. Plastic bins also help to keep things contained. While I wouldn't go to great lengths to abuse them, FWIW the fins don't seem that susceptible to damage.
    Whatever method you employ, just be sure to maintain adequate airflow over the fins and around the inside of the compartment.
  • Tabaz Tabaz Member Posts: 2,379
    They plastic blue fins work fine - just wish they were a little taller so I could put more stuff on that section of shelf.
