cs model bed size
PapaPapa Member Posts: 27
any ideas on how to sleep on smaller bed size compared to s model
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,037
    How tall are you @Papa?
    @Papa, welcome to the forum.
  • PapaPapa Member Posts: 27
    We bought the cs-s and know we have to decide to make and unmake the bed every day
    we will sleep wheel to wheel. A little different. From our t@g
    If you sit outside or in a screenhouse or attached tent, just leave the bed made up.  If you have a heavy foam pad, there isn't really anywhere in a CS to move it out of the way.  We use a thinner, but comfortable mattress pad sandwiched inside a duvet as a base.  It folds up easily and can be placed on part of one of the benches.
  • 2Cougs2Cougs Member Posts: 922
    We sleep wheel to wheel, use sheets and blankets, and leave the bed made unless circumstances arise where we have to take it down.  Hubby calls the T@b his warm, dry bed... And we do everything else outside.  Have taken bed down and put table up when it was pouring rain and when insects unbearable.
  • skwheeskwhee Member Posts: 246
    @Papa
    At 6'0" and 5'4" we spent 700 nights in our CS. We'd moved up from a Silver Shadow, similar to your T@G. We decided quickly to replace the table with slats and replace the cushions with custom made mattresses. We created a bed more comfortable than the one at our house! We essentially used the cabin of the CS as our bedroom. With some creativity we could convert it to a sofa/lounge for reading or watching TV. The rest of our living was outdoors. If our stay was multi-day we would put up an awning or screen room attached to the keder rail on the side of the T@B and sometimes a 10x10 canopy over the kitchen. We'd furnish those areas with rugs, chairs, and tables creating living and dining areas.
    Hope this helps! May you have many wonderful adventures in your T@B-CS.
    Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 T@B 400
