How to reset the emergency braking system on a T@B
Om3
Member Posts: 72
Do we need to "reset" the emergency braking system on the T@B 400? Hopefully, you will never need to have your T@B 400 use the emergency brake,
but...IT WORKS!!!! It was amazing to see...despite the concerns.
The pin at the end of the cable needs to be re inserted into the breakaway switch box. As long as it is out your brakes will stay in gauged till the battery runs down. That may be why your tire wore flat.
- Hash T@B Fun
We did reinsert the cable before continuing. The tire wore flat at the time of the emergency engagement as we came to a stop.
You did great! Just putting the pin back in is the reset.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)
Thank you, Ratkity!
- 916 Introductions
- 72 Teardrop Groups & Links
