{ have searched and can't find any 3rd stop/brake light posts }
Issue:
Question:
For a 320S. Has anyone routed wires from the
License Plate area to the Alde Tank area?
Did you have any issues or surprises ?
Early investigation finding:
+ Curved Rear Plastic that holds tail lights
is the TaB wall . . . there is no Azdel or wood material behind most
of it. There is a ¼ inch or so insulation pad. {Now I understand
why morning sunlight makes the rear shelf area glow red (unit is Red
Trimmed) }
+ there is a foam board shelf below the rear
storage area and above the Alde Convectors that is taped to the
insulation pad.
+ Big picture hope/plan is to route from a
drilled hole above the license plate to the Driver Side. Just not
sure how the insulation pad and foam board shelf might impact.
The wires for the tail/stop/license lights run across from driver to passenger lights right behind the plastic rear cover. I removed the license light to access the wiring, drilled the hole for the third brake light and fished the wiring through. This is on an '04 DM T@B - so construction is different, this has a plywood wall behind the plastic rear cover. Installed the logic unit inside drivers side light cowling. Swapped out the original tail lights for LED units.
T@BMahal
'04 #100
-+- Drill Mounting Hole for LED light {5/8 inch dia}
-+- Run Cable Snake from mounting hole to behind Left Tail Light,
Between T@B Plastic shell and Insulation Barrier
-+- Cut Insulation Barrier at rear of Alde Tank space, grope around until Snake found.
-+- Replaced Snake with guide strings; ran wire from mounting hole to below Alde tank for
ground (tapped at Left rear Side Maker Ground) and to Driver Wheel Well for +12V to
Light (used wire race in Alde space)
Was surprised the Curt Convertor is not solid state, it uses a relay. Can hear on attached video . . . that I can not upload . . .
Adventures: 51 Nights: 322 Towing Miles 41,200+
Have never seen what you are referencing.
So 400's do have the extra clearance lights,
guess since I consider a 400 way too big for my needs
have never looked that closely.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Carol, The four wires you need are the same four that exit the upper cabinet and enter the hatch in the upper left corner for the tail light wiring. I made the splices in the wires inside the cabinet before they pass through to the hatch. I don't recall if the colors matched the new lights wires. I ran the wires to the center along the inside top edge of the cabinet concealed in a piece of small wire molding.
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
I fabricated it out of aluminum flashing with a few simple folds. A cereal box cardboard prototype helped me get the details right. The aluminum folds nearly as easily.
Have fun...
Bob
MOUSE-KE-T@B
Harvest, AL
