What brand of RV antifreeze do you use? I am going to do the antifreeze method of winterizing. I have read some negative reviews of the Walmart brand of the pink stuff "Super Tech RV & Marine"--anyone used this brand? Would like to find a propylene glycol (no alcohol) based brand, or are all RV antifreeze the propylene glycol. Camco brand, of course, appears to be the most expensive. Are they all the same?
2016 Nissan Frontier SV V6 4x4
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
0 ·
Of course the "good" stuff is more expensive as most things in life!
As far as brands, I need to look at what I got from my local RV place. I had to ask for it, the stuff out front on the shelf was a blend! I have heard that Rain-x makes it ,but be sure it isn't a washer fluid!!
Most brands are rated by burst temp, NOT freezing temp which is typically much warmer. The burst on most is -50F, BUT some brands also sell burst of -100F, of course for more money.
https://recvehicle.com/winterization-and-rv-antifreeze/
Woohoo!
Woohoo!
Woohoo!
brand.
Woohoo!
